Traffic Usage Monitoring
You can troubleshoot network problems by using the Equinix Connect and Internet Access: Traffic Usage window to monitor and analyze the internet traffic that passes through a port. View a summary of the traffic usage for a single port, or export a detailed report for each port that your organization has purchased. Summaries of inbound and outbound traffic usage are available for the past three months.
  1. Sign in to the Customer Portal.
  2. Click Network Management and select Equinix Connect and Internet Access.
  3. To display a summary of traffic usage for a single port, use the Select Port fields to specify the port.
    • Search for a port – Type the name, or click the magnifying glass to choose a port from the drop-down list.
    • Metro – Click the drop-down list to choose a client metro location.
    • IBX – Click the drop-down list to choose the IBX.
    • Port – Click the drop-down list to choose the port.
    The bottom of the window displays the Traffic Usage Summary for the past three months. The summary includes the speed of 95% of the inbound and outbound traffic in Mbps.
  4. To export a full report of traffic details for a port, scroll down to Generate Traffic Report. Select a month, then select Download. A detailed report is exported.
