Security
Equinix Internet Access provides security features that offer protection, detection, and mitigation of various types of threats.
Remotely Triggered Black Hole​
During a potential distributed denial-of-service (DDoS) attack, Equinix blackholes a single IP address temporarily, and pushes the black hole advertisement towards the northbound ISP. All IP traffic towards that IP address is dropped. This action prevents saturation of all upstream ports, thereby protecting the Equinix network and its customers. This also prevents saturation of private connections on the Equinix Fabric network, in case an attack occurs over an Equinix Internet Access with Fabric service.
This triggering happens automatically when a single host exceeds predefined limits for traffic and packet rate in a pattern that suggests a volumetric attack. Once the threat is removed, the customer whose traffic was blocked is reinstated after sufficient time has elapsed.
Monitoring and Notification Process​
Your ports are actively monitored at all Equinix-employed Network Monitoring Systems (NMS) for all Equinix Network equipments. The process involves these steps:
  1. You can inform Equinix if your service is impacted. NOC can restore the services for you.
  2. For BGP users, the port is monitored by Monolith and the BGP.
  3. For VRRP users, the NOC receives a notification for the successful switchover from the host to the client port.
Equinix monitors the upstream provider availability and bandwidth utilization with Cricket. With this data, we can identify any outages on the upstream transit providers and manage the traffic.
Other Security Features​
Equinix Internet Access provides additional security support:
  • Generation of Automated Internet Routing Registry (IRR) filters
  • Rich Border Gateway Protocol (BGP) community; no-advertise by provider and region
  • Transfer-net from non-routed address space
Adding Security to your Internet Access Service​
Customers can take additional steps to safeguard their apps against attacks that come over the internet. These suggestions are optional, and up to your discretion.
Monitoring Traffic Usage​
Customers should monitor their traffic or create alerts for sudden large spikes. Traffic can be viewed by navigating to Traffic Usage for Equinix Internet Access in the Customer Portal. If the source IP addresses are unknown or the traffic type is suspicious, an attack is likely. Contact Support to immediately blackhole the traffic.
Access Control Lists and Log Monitoring​
An access control list (ACL) is a list of rules that specify which users or systems are granted or denied access to a particular object or system resource. This strategy is ideal if your traffic is largely internal traffic, where addresses and systems are known.
In addition, you should monitor logs for suspicious or unknown behavior. This is a good way to keep your control lists current.
Firewalls​
Customers can select from a wide range of third-party firewall implementations based on their needs, ranging from simple network firewalls to specialized application firewalls. Virtual customers can also leverage Equinix Network Edge service offerings.
Intrusion Detection and Prevention Service Appliances​
Customers who use Equinix colocation-related products can take advantage of a wide range of hardware and software appliances to guard against DDoS attacks. These users can select a capacity and price that meets their needs. This approach is ideal if you are a colocation customer with your own space and hardware.
Cloud Security Providers​
Through a cloud security provider, you can conveniently add protection without deploying any hardware or software. This solution is viable if you have your own publicly routable IP address with Equinix Internet Access.
