# Managing Your Subscriptions View and manage your Messaging Gateway subscriptions from the *My Subscriptions* list in the Customer Portal. 1. Sign in to the [Customer Portal](https://portal.equinix.com). 2. From the global navigation menu, select **Developer Settings** > **Messaging Gateway**. ![](https://docs.equinix.com/assets/images/subscription-ecp-step0-a9161ccf9e632050f83ddb969f6d16f2.png) 3. Select a subscription. 4. Click the menu located on the right side of the subscription. 5. Select an action you want to perform. ![](https://docs.equinix.com/assets/images/manage-subscriptions-menu-24a475b2492262d56e40eb87edcf2bd6.png) ## Send a Test Notification[​](#send-a-test-notification "Direct link to Send a Test Notification") 1. Specify a feature, sub-feature, and a status for sending test notification. 2. Click **Send** to send a test notification or **Cancel** to abort. ![](https://docs.equinix.com/assets/images/manage-send-test-4c2731f3573e07619236a40bb329ac84.png) ## Edit a Subscription[​](#edit-a-subscription "Direct link to Edit a Subscription") 1. Edit your subscription data. 2. Click **Update** to save changes or **Cancel** to abort. ![](https://docs.equinix.com/assets/images/manage-edit-subscription-f8a67ca952f0312cfa68aabd512d61ad.png) ## Delete a Subscription[​](#delete-a-subscription "Direct link to Delete a Subscription") 1. Make sure you want to remove the subscription from the list permanently. 2. Click **Delete** to remove the subscription or **Cancel** to abort. ![](https://docs.equinix.com/assets/images/manage-delete-subscription-d4d45dd62a9223f783fe7e2bef2f3afc.png)
