# Asset Level Permissions Assets represent the resources assigned to your Projects. You can: * Assign permissions to assets - Control who can access and modify assets within projects. * Manage assets - View and edit access to assets within projects. * Remove permissions - Revoke access to certain assets when needed to maintain security and control. **Note:** * Custom Roles cannot be assigned to asset level permissions. * Currently, we can assign asset level permissions to one type of assets: Fabric Port ## Assigning Role Permissions to an Asset[​](#assigning-role-permissions-to-an-asset "Direct link to Assigning Role Permissions to an Asset") 1. Sign in to the [Identity & Access Management](https://portal.equinix.com/iam/accessmanagement/resources) portal. 2. Click *Users*. 3. Select a project. Click the *Context Switcher* drop-down menu, select a Project, then click **Go**. ![](https://docs.equinix.com/assets/images/iam-context-switcher-c22e988655ada02af376c0c7f7231180.png) > **Note** > > Do not select an Organization. You cannot assign asset level permissions through an organization. 4. Select the users who are getting role permissions to your assets. Click **Grant Access**. ![](https://docs.equinix.com/assets/images/asset-permissions-select-users-8f5cfa86fa6953796d1f3a84b4dd9418.png) 5. From the *Choose Access Assignment* menu, click **Assign Role on an Asset**. ![](https://docs.equinix.com/assets/images/asset-permissions-role-project-asset-menu-232fd999b532f09bd305c3a58ec46996.png) 6. A side menu will display the available assets. Select the assets that you are giving users access to. ![](https://docs.equinix.com/assets/images/asset-permissions-select-assets-13c00f22e638b3d9a7657ead58cc2b4f.png) Click **Save Changes**. 7. Back on the main page, click **Next**. 8. The next screen shows the Roles you can assign to the assets you have selected. These roles represent the permissions for what the users can do to the assets. ![](https://docs.equinix.com/assets/images/asset-permissions-select-role-for-assets-db0b54bd87d4b941562ea87ee90f654b.png) Select the roles and click **Next** 9. You will be prompted to review and confirm the *Asset Level Permissions* for the selected users. Click **Submit**. ## View and Manage a User’s Asset-specific Roles[​](#view-and-manage-a-users-asset-specific-roles "Direct link to View and Manage a User’s Asset-specific Roles") 1. Sign in to the [Identity & Access Management](https://portal.equinix.com/iam/accessmanagement/resources) portal. 2. Click *Users*. 3. Select a project. Click the *Context Switcher* drop-down menu, select a Project, then click **Go**. ![](https://docs.equinix.com/assets/images/iam-context-switcher-c22e988655ada02af376c0c7f7231180.png) > **Note** > > Do not select an Organization. You cannot assign asset level permissions through an organization. 4. Locate the user and click the user name or use the options menu, and select *User Details*. 5. Click on *Asset-specific Roles* tab to view the role permissions assigned to the user. ![](https://docs.equinix.com/assets/images/asset-permissions-view-roles-ca532e899580df179bbc79634d44cbdf.png) 6. Locate the role and use the options menu to select **Manage Assets**. A side menu will display the available assets. You can edit the available assets. ![](https://docs.equinix.com/assets/images/asset-permissions-manage-d0ae0e475f95f473aa6968ce319d8c29.png) 7. Click **Save Changes**. ## Remove User’s Asset-specific Roles[​](#remove-users-asset-specific-roles "Direct link to Remove User’s Asset-specific Roles") 1. Sign in to the [Identity & Access Management](https://portal.equinix.com/iam/accessmanagement/resources) portal. 2. Click *Users*. 3. Select a project. Click the *Context Switcher* drop-down menu, select a Project, then click **Go**. ![](https://docs.equinix.com/assets/images/iam-context-switcher-c22e988655ada02af376c0c7f7231180.png) > **Note** > > Do not select an Organization. You cannot assign asset level permissions through an organization. 4. Locate the user and click the user name or use the options menu, and select *User Details*. 5. Click on *Asset-specific Roles* tab to view the role permissions assigned to the user. ![](https://docs.equinix.com/assets/images/asset-permissions-view-roles-ca532e899580df179bbc79634d44cbdf.png) 6. Locate the role and use the options menu to select **Remove Role**. ![](https://docs.equinix.com/assets/images/asset-permissions-remove-3671b440e38918fce657dd24f674a35f.png) 7. Confirm you selection and click **Remove Role**. All Role permissions to the asset will be removed for the user.
