# Monitoring Connection Utilization Monitor your connection utilization and ensure sufficient bandwidth for your customers. Adjust your port usage as needed to improve performance. To view connection utilization statistics: 1. Log in to the [Customer Portal](https://portal.equinix.com/fabric) > *Fabric Dashboard*. 2. From the *Connections* menu, select **Connections Inventory**. 3. Locate and click the connection you want to monitor. ![](https://docs.equinix.com/assets/images/monitor-inventory-3c0390fdbd39a546ea15b4b773a4a72a.png) 4. Click the connection to bring up the *Connection Details*. ![](https://docs.equinix.com/assets/images/monitor-connection-details-ed4e762a3a97e9213be3d04fb5ed5a0a.png) ## Metrics[​](#metrics "Direct link to Metrics") The *Metrics* tab shows bandwidth and dropped packet data. Metrics are supported on connections where: * the a-side of the connection is a port (except for e-tree networks and virtual devices). * the connection is between a Fabric Cloud Router and a port. * the connection is between a Fabric Cloud Router and a Cloud Service Provider. The *Usage* graph shows inbound and outbound bandwidth. ![Screenshot of the Usage Graph](https://docs.equinix.com/assets/images/monitor-usage-graph-4e196fbc4cd872c4fccb0966a235649d.png) The *Packet Drop* graph shows the inbound and outbound packets dropped for the a-side and z-side of the connection. If only one side of the connection is a port, packet drop metrics are only available for the port side. ![Screenshot of the Dropped Packets Graph](https://docs.equinix.com/assets/images/monitor-dropped-packets-graph-bcf2ca5e92348ba6c09d4f2659115ba0.png) From the *Time Period* drop-down list, select a predefined setting or choose *Custom Date Range* to define your own time interval. Use the sliders at the bottom and to the right of the graph, to change the scale. Hover over the graph to see traffic readings in a specific timestamp. ### Metric Alert Rules[​](#metric-alert-rules "Direct link to Metric Alert Rules") Set alerts when a connection's bandwidth or the number of packets dropped exceeds a certain threshold. For instructions on configuring connection bandwidth and packet threshold alerts, and how to receive those alerts, see [Managing Metric Alert Rules](https://docs.equinix.com/observability/streaming-data/api-managing-metric-alert-rules.md). ## Events[​](#events "Direct link to Events") The *Events* tab shows connection lifecycle events for any status change to a connection, including provisioning, deprovisioning, and failures, when available. Not all connections support events. ![Screenshot of the Events Table](https://docs.equinix.com/assets/images/monitor-events-c80a5135813f448cc874644621992be2.png) Filter the table by event type, user name. From the *Time Period* drop-down list, select a predefined setting or choose *Custom Date Range* to define your own time interval. Events are not refreshed automatically. Click refresh to update the data in the table. ## Connection Monitoring in the API[​](#connection-monitoring-in-the-api "Direct link to Connection Monitoring in the API") The Equinix API offers the ability to create and customize a stream that collects usage data for your connection or connections. Once you have created a stream you can view the usage data from the Equinix API or create a subscription to have the data sent to your data collection platform. To configure connection monitoring from the API: * [Create a stream](https://docs.equinix.com/observability/streaming-data/api-managing-streams.md). * [Add your connection or connections to the stream](https://docs.equinix.com/observability/streaming-data/api-managing-assets.md). To get your data, either: * [Create a subscription](https://docs.equinix.com/observability/streaming-data/create-subscription.md) and send the data to a data collector.
