Order an Equinix Fabric Port - New Ordering Flow
Equinix Fabric ports are available in various configurations including standard and metro ports, remote ports, and extended ports, depending on where customers are located in relation to the physical Equinix Fabric equipment.
Prerequisites
Before ordering an Equinix Fabric port, you must have:
An Equinix Fabric account, with one of the following IAM roles assigned: Fabric Port Manager, Fabric Manager, Fabric Service Provider, or Fabric Partner Resource Manager (applicable to Fabric reseller admin users who perform port sharing with end customers).
Note: For more information, see Roles and Permissions Reference.
Important: End customer users are not allowed to place Fabric port orders.
The Network Ports ordering permission for a specific IBX data center.
To assign the Network Ports permission:
Log in to the Equinix Customer Portal.
From the Administration menu, select User Management.
Locate the user you want to grant Fabric ports ordering permission, click
and select Manage Permission.
Click Ordering.
Check the Network Ports permission for select IBX data centers.
Order a Fabric Port
Log in to Equinix Fabric.
From the Ports menu, select Order an Equinix Fabric Port.
Select a project that newly order port will be assigned to.
Note: For more information, see Identity and Access Management - Projects.
Select where you want to terminate your port:
My Cage in an Equinix IBX – You have your own equipment in an Equinix data center.
A Building Meet-Me-Room (BMMR) – You are using a neutral cage to connect to others.
A third party with a cage in an Equinix IBX – You are ordering a remote port and connecting via another party.
On the Try Our New Port Ordering Flow? prompt, click Yes, Try New Port Ordering Flow.
On the Customer Demarcation page, configure the demarcation point, depending on where you want to provision your port:
My Cage
In the Connection Source section, select My Cage.
In the Port Type section, select port type:
Ethernet Virtual Private Line (EVPL) – EVPL ports allow for creating multiple connections, segmenting the traffic based on the VLAN tags.
Ethernet Private Line (EPL) – An untagged port that allows a transparent flow of traffic. An EPL port allows for one connection and there is no separation of traffic.
In the Redundancy Type section, choose redundancy option:
Single LAG Port – Order a single port.
Redundant Ports – Order a pair of redundant ports. Applicable to EVPL ports.
From the Number Of Lag Ports in this new LAG Group drop-down list, select the number of ports in a LAG group. Applicable to single LAG ports.
In the Location and Account section, select an IBX data center where you want to procure a Fabric port and a billing account that's enabled for ordering in the selected location.
Tip: Click Create Billing Account to create a billing account which you can use to place your order.
In the Port 1 Patch Panel Details/Primary Port Patch Panel Details/Secondary Port Patch Panel Details section:
Select cage, choose cabinet, then select patch panel.
Select a connector type, then choose ports.
Click Next.
Another Party's Cage
Important: Delivering a Fabric port to another party's cage requires a letter of authorization.
In the Connection Source section, select Another Party's Cage.
In the Letter of Authorization (LOA) section, provide a document that authorizes you to provision a port in selected location.
Click Next.
Building Meet Me Room
In the Connection Source section, select Building Meet Me Room (BMMR).
In the Who will install the final connection in the Building Meet Me Room?, select:
Equinix - To have Equinix technician carry out port installation in the BMMR.
Important: This option requires providing a letter of authorization.
Self - To have the port installed by your personnel.
Click Next.
On the Port Configuration page:
Select connections package:
Unlimited - You are charged a single MRC that includes the port and any number (up to the allowed amount of VLANs) of local connections made from the port. Applicable to EVPL ports.
Standard - You are charged a monthly recurring charge (MRC) for each connection made from the port.
Note: Select markets offer the Unlimited Port Plus connections package that allows for creating any number of local and remote connections up to the allowed amount of VLANs (up to 4095 VLANs) at no additional cost. This option is available in offline ordering only. For details, see Connection Packages.
Select port speed.
Select port interface type.
Select data plane, indicating the Fabric's physical device your asset is connected to, in terms of hardware stack redundancy:
Plane A - The asset is connected to one of the Fabric's physical device in a redundancy pair.
Plane B - The asset is connected to the other Fabric's physical device in a redundancy pair.
Select an IBX data center where you want to provision your port.
Note: Applicable when there's no capacity on the Fabric switch in the IBX data center where the previously configured demarcation point is located.
Click Next.
On the Review Order and Additional Information page:
In the Pricing Information section, select I agree to acknowledge the pricing disclaimer.
Review information in the Customer Demarcation, and Port Configurations sections.
In the Contact Information section, review contact details for technical inquiries. Click Change Technical Contact to update the information.
In the Purchase Order section:
Enter a purchase order number, or click Select Purchase Order Number to choose from the pool of eligible purchase order numbers.
Provide customer reference identifier, that will help you identify this order on your invoice.
Click Order Fabric Port.
