Wasabi Hot Cloud Storage On-Demand
Wasabi On Demand Storage-as-a-Service can be reached from Equinix Fabric locally in several metros and remotely from any Equinix Fabric location. Connect your physical or virtual infrastructure to your Wasabi network through Equinix Fabric to gain access to enterprise or branch locations, cloud providers, partners, and suppliers from a single access point.
Prerequisites
An Equinix Fabric account.
An existing port or Network Edge virtual device. For information about ordering an Equinix Fabric port, see Order an Equinix Fabric Port. For information about ordering a Network Edge device, see Create a Single Virtual Device.
Permissions to access the A-side port or Network Edge device. For information about permissions, see Equinix Fabric Permissions.
An existing Wasabi Hot Cloud Storage account.
Provision a Virtual Circuit to Wasabi Storage Region
Contact your Wasabi Account Manager or email sales@wasabi.com to order an Equinix Fabric Virtual Cross Connect (VXC) circuit. Make sure to include the following information:
Wasabi Account ID
AWS Account ID (for AWS DX circuits only)
Wasabi Data Center location
Service Rate 1Gbps increments
Specify your layer 3 routing requirements
You can choose to create a NAT interface for the A-side or use BGP routing. In case of the latter, include the ASN and Public Prefix to advertise to Wasabi.
Note: Private Prefixes require further discussion.
Wasabi provides the point-to-point IP assignment with a /31 prefix. Request /30 if required, along with any additional requirements.
In response to your request, you will receive a circuit identifier (example: DEVOPS-1234). This identifier is required to create Equinix Fabric connection.
Connect to Wasabi Hot Cloud Storage On-Demand
Log in to Equinix Fabric.
In the A Service Provider card, click Connect to a Service Provider.
Enter Wasabi in the search field.
On the Wasabi Technologies, Inc. card, click Select Service.
On the Wasabi Hot Cloud Storage Direct Connect card, click Create Connection.
In the Origin section, select Port, or Virtual Device, then choose metro and select a port or a virtual device instance.
In the Destination section, choose desired Wasabi Cloud Region and click Next.
In the Connection Information section, enter:
In the Purchase Order Number section, provide the Wasabi circuit identifier.
Select a predefined connection speed option or enter desired connection bandwidth value, then click Next.
Review your order and click Submit Order.
Tip: Click Design Summary to download a PDF document containing connection details.
Once you have submitted your virtual connection order, Equinix will send a notification the Wasabi operations team. The Wasabi Direct Connect process is not fully automated, which means Wasabi will manually review the order submission request. The connection status will remain Pending Approval until Wasabi approves the request. Wasabi will approve the connection request in the Equinix Fabric portal. Typical turnaround for order approval is less than one week.
