# Order Cross Connects with a Letter of Authorization (LOA) You can order Cross Connects directly through the [Customer Portal](https://portal.equinix.com/) or API using a Letter of Authorization (LOA). ## Before You Begin[​](#before-you-begin "Direct link to Before You Begin") Ensure you have one of the following from your Z-side provider: * A Digital LOA file that you can upload. * A file containing a Digital LOA token (emailed to the designated user contact after a Digital LOA is created). * An LOA ID generated online through the [Digital LOA Manager](https://docs.equinix.com/digital-loa.md). An LOA provides all the Z-side information for the Cross Connection. If you don’t have an LOA, you can still [order a Cross Connect without an LOA](https://docs.equinix.com/cross-connect/ordering/xc-order-cc-without-loa.md). There are two options: 1. **Order a Cross Connect manually** by contacting the Global Service Desk (GSD) by email or by phone (email orders result in higher accuracy). * These orders are processed manually, which may result in longer booking times. * A GSD agent may reach out to request missing details or clarify requirements. 2. **Order Cross Connects without a signed quote** * Service orders and quotes are typically used for first-time installs by new customers, or when a customer purchases Cross Connects that deviate from customer-specific pricing. > **Note** > > To order Cross Connects in the Customer Portal and API, you must have Cross Connect and Intra-Facility Cables ordering permission. ## Steps to Place an Order[​](#steps-to-place-an-order "Direct link to Steps to Place an Order") 1. Sign in to the [Customer Portal](https://portal.equinix.com/). 2. From the *Orders and Tickets* menu, choose *Cross Connects*. ![Orders and Tickets menu with Cross Connects highlighted](https://docs.equinix.com/assets/images/xc-orders-cc-d35a5813039bfe279a4c60ca511f58b4.png) 3. Click the Cross Connect card in the Interconnection Catalog. ![Interconnection Catalog with the Cross Connect card](https://docs.equinix.com/assets/images/xc-orders-unified-cc-73b10b37c48b3255373bbf85ce2e9ca5.png) 4. Review the information about the *Unified Cross Connect Ordering Experience* and click **Next**. > **Note** > > A blue progress bar is displayed across the top of the page. Hover over the bar to view a drop-down list showing your current step and overall progress. Completed sections are shown with check marks. Click a completed section to return and make edits. ### Use a Digital LOA[​](#use-a-digital-loa "Direct link to Use a Digital LOA") In the *Specify LOA Preference* section, click **Order with a Digital LOA**. Under *Order with a Digital LOA*, select an LOA ID to use for this order. You can filter the list by entering an ID or a keyword. Click **Next**. ![Specify LOA Preference with DLOA token selected](https://docs.equinix.com/assets/images/xc-orders-use-dloa2-ec65eed5b575d02a49da8a5d11af2a65.png) ### Order with LOA or DLOA[​](#order-with-loa-or-dloa "Direct link to Order with LOA or DLOA") In the *Specify LOA Preference* section, click **Order with LOA or DLOA**. DLOA stands for Digital Letter of Authorization. 1. Under *Order with LOA or DLOA*, select either *Connect to a provider* or *Connect in Building Meet Me Room*. * When *Connect to a provider* is selected, you can * click **Browse** to locate an LOA file on your local drive, or * drag and drop the file into the form. The file size must be 2 MB or less, and must contain LOA metadata. Once the file is uploaded, provider information from the LOA is displayed. * To use this auto-selected information, click **Next**. * To choose another provider, click *Select Provider from the List*. Choose a Z-side provider from the dashboard list, and click **Next**. ![Order with LOA or DLOA with Connect to a provider selected](https://docs.equinix.com/assets/images/xc-orders-provider-92fbcc2622ae0bee427a8e0d795ca0be.png) * When *Connect in Building Meet Me Room* is selected, you can choose who will order the final Connection in the Building Meet Me Room ![Order with LOA or DLOA with Building Meet Me Room selected](https://docs.equinix.com/assets/images/xc-orders-BMMR-a54850712b124fb8b99b28240fec67d4.png) ## Configure the Connection[​](#configure-the-connection "Direct link to Configure the Connection") In the *Connection Overview* section, choose an A-side IBX data center from the drop-down list. The Z-side IBX is provided by the LOA that you selected or uploaded. In the *Connection Details* section, click **+ Add Connection**. The *Asset Selection Details* form is shown. ![Asset Selection Details panel for the A-side](https://docs.equinix.com/assets/images/xc-order-conn-aside-70bb258c9924199041569ac3af288324.png) 1. Enter a Patch Panel number, or choose a Cage, a Cabinet, and a Patch Panel from the drop-down lists. By default, the Connection Service and the Media Type are set to Single-Mode Fiber. 2. Choose a Protocol Type and a Connector Type from the drop-down lists. 3. Choose Port A and optional Port B from the drop-down lists, or from the Visual Patch Panel display of available ports below. The Next Available port is the default. 4. To request that Equinix install the new Cross Connect from the panel to your equipment, select *Patch my equipment* and choose the Device Cabinet, Connector Type, and Port. Additional Smart Hands fees will apply. 5. Select *Add Cross Connect Light Link Verification* to receive a light link reading, and a transmit and receive verification after the cross connect is complete. To verify correct transmit and receive alignment, ensure your Z-side connect partner has their end fully extended to their equipment and their port is enabled. An additional charge based on your contract pricing will apply for each connection. 6. If your Digital LOA includes additional connections, click *Next Connection*. The *Asset Selection Details* form displays information for the next connection. By default, the details from the first connection are displayed. 7. Change the values for the Cage, Cabinet, Patch Panel, and ports as needed. To provide the details for additional connections, click Next Connection. 8. Repeat the previous steps for all the A-side connections. When the connection details are complete, click *Save*. The updated A-side Connection Details are displayed. ## Review the Connection Details[​](#review-the-connection-details "Direct link to Review the Connection Details") Review the updated list in the *Connection Details* section. * To make changes, click the pencil at the end of the connection row. Edit the information in the *Asset Selection Details* form and click **Confirm Selection**. * To delete a connection, click the trash can next to the connection. Click **Delete Connection**. At least one connection must be present to complete the order. To view all the details and charges, click **Show Order Summary**. This information updates as you progress through the ordering process. ![Show Order Summary and Next buttons](data:image/png;base64,iVBORw0KGgoAAAANSUhEUgAAAUwAAAA/CAYAAACLr/GEAAAACXBIWXMAABYlAAAWJQFJUiTwAAAAB3RJTUUH5gwBAwIkffbgUQAAEv1JREFUeJzt3Xl4FdXdwPHvnbl79kBSiKEYoQgkJRADBMSQuhQUqygF3hREsUKxSqEIWOTVqogKFdBqhVZxQ6RUQ0FQxBbfiJggUiAsj6wGFEIMkO3m7nfmvn/MTcieGwzJxZ7P8/A8w2XmnDPbb845czij8/v9fgRBEIQWSR1dAEEQhMuFCJiCIAhBEgFTEAQhSCJgCoIgBEkETEEQhCDpO7oAgiC03vJtDt7Md3KgyIeidnRpQossQUqCnruHWLg/09qmaevEsCJBuLzct6qC1TtdHV2My8KEQWZevSuqzdITTXJBuIws3+YQwbIVVu90sXybo83SEwFTEC4jb+Y7O7oIl522PGYd2oe5Zcdh1ny0h71Hz3DweHFHFkUQ2lVyjy70/0lXskcOYETG1UFvd6DIdwlL9cPUlsesQ/owy21OHnp+E299sKu9sxaEkDNpVDovzL6dcIuxxXUt079rhxL98Dhf/FGbpNMhTXIRLAXhgrc+2MWM5zZ0dDGEILR7k3zLjsN1guWkUek8Mvl6eiR2au+iCEKHOXi8mJdz8vnbuh2AFjTH3dSvVc1zof21ew1zzUd7apYnjUpn5aNjRbAU/usk9+jCX+bewW/HDq35rfa9IYSmdg+Ye4+eqVl+ZPL17Z29IISUqaMH1yzXvjeE0NTuAbP223BRsxT+2yX36FKzLEaKhD4xDlMQBCFIImAKgiAESQRMQRCEIImAKQiCEKTLe3o3xUtRmYoPic6dDbTtRE6XIx/nzik40BEZYyRa7ujyCMIPS4gGTIXT+6p4YIOb/FI/laqOGKtEcj8j82+0khUXKHaRnRsXuynEwGsvxpLdsYVukeNUFQs/dJFzVOGkC2SjjsR4PZNGhDGzv6kNAr6TqU842IzErLlxLOzWBoVujuJhy4dVzMvzcbzKj2LUERstc2eGhZnDrVzZ8v/0EzrYxPvieCVVAoeHOc+W8VJZvRVGx+K8wQCVbqbML+ftS1CGazLCyU7UQamH2Z+4L0EObSckm+Rn8yu45hUXW0r82CUdcUY/ZVUK2/Oc3PxkKZP2Xm4TEHjYuuYcXRfZWbpfC5aR4TpMPj8nT3lZsLKcqxZXsFvp6HK2hoc1K8oZ/bGXr6r86K06wlQ/Z0t8/PV9G30eK2WjmFjn8mE18viUCIZ1QNZ9Uiw8MNzKA+mh/4QNwRqmg6c3eakA+o+I4tNbzRgBj8PJPzfYmXXUwOz+IVjsJinszqng9jwVBR3pWWH8fXQYV8iA4qVgu40x67yc/tbFLSsk9j8QQVxHFzkYxxw8csgPksxj82KY10UGFMpPOnlirYNPeln4haWjCym0Rlg3K2/e66PHa+JJ15QQjDwKJysBJK5L0YIlgNFqYXy2hfFNbOU4VsnoNS7+r8QPZpmf3RTGOz+31G3melyszLHzl70KRxx+ZLOOHt1NPDMhnBExWoffvpyzDM5VIcnCmVmRRAM4bIyY52CbKjFtRhzLelJnXbm3ldIHImj0+VhSxW9yVRQg9eYoPrvFdOHfZAOpw2PJN5by03e8VBxy8vvdVt5Ok+HbcvpWdzcsNHHgVQcvFcKDgaa245SNGatdvF+sUqnqSEgw8MiEpk6nj4Of2piy1cvBMj+YdfTobmb51EgGVxe6hfwaOKtSDBClZ0SX6s5Smeju4SybG15n1Zpj2tuK84GIZn53Mv+PlSwthZt/Gcnw/XaePq7g0kskp1l4d5wFe34l93zs5XCFH59RYnCGldVjwgIPme+7vZuNOXaeKfBxuMKPQwWjWSI52cwrv4oguaVj9ZCFky/ayfFA5phYtmQZLlx6u0tJeN2L3Whg7eJYbgu1/mUVFAkSUsNZO9TD+LwWmjsxRubcFs7UFD1dzTq8LpWir53M+HsV/y4DekaQd7+VAUY/e7aWM3S9B4CJ98axYoAE5W6mLy2n15QfMbP6+upmxfmiFfDy/PRS5l3K/b1IIdgk19MnFkDl5ZXnmb/DyTlPS9t4mfGik3+Xg1kPHpfClo2V3JHrvbBKpY1xj1XwYJ6PIz4dQ1L0JBv8fHXYxejHS5l/QrtA+g0ykARw0sfmwDXjKfDyuaqVaUtB9dPXydp92sdUfp5mbTxYAt/u8nIAINzI4trBspa4IWH8rguAn/U76z/dFZ59voqlhSrVh8Fzopwhf3Lw9ikVuyQxrK+MtcTDg39y8HGD1BV255Qx+D0Pe2w6kntV77eTrP8t5b0Gk1E3zK9RiZJ2nMrcjPtzOWu/9tJ281rDx+sq+cNxFVkCj0tlT56da+afJ22th3120Ad+/yy3iuxPGpb0Yrc/dNTLHht0727g9iQJvUdlz38cDF5awdcNcql3rORwHkzXbqltOxx8W2u9j/7jww6E9TWFXrAEOO1k+Sk/SBK3jYnimZ7NrWzkmSnRPJluoKvs58gJH2WyxFV9w1g/K4qJAMdszP3Mix0dA64L19IbHMUTqRKyqvLBZhuvl8E3RV72lwdmmHQo7DzhZecJH99c8h2+OCEYMC3MyTbRSwKl3MfS1ZV0e+g7Oj18jtE5VRxs4i7uMSySkiXxfPdcDIuStN+27XZSDoCXNaucbLRDVG8rhxfH8a/fdCLv6Rg2pUugqix9xcYOgG5GRkQCqo8tBwAUcnZ7qX7eFu5zsw/gvIetpYCk5+bUpu+A7YWBLRP1ZDa5lomRvbRToZzxaenXUDlyVkf60DC2/TGKOQlunlvt5ohad1/2L45hRS8dDeoFx2yMyVVRJD2LHoslb7q23yt66cDpZc6G+mGufn5NFLlbGCuGSsjA6aNu7llWSqcZJSQsKGX+Dtf3D56dTHz+XDxFSzpp5wiosPvpkdnwPH++1xU4z993exPZ90Rxflk8u2fF8vdZcZz5vYkkQDnt4a3T9TNpeKwybjCSAnDay6qSwGqKk38c8gMSdw0P+75H5hLxMyfHyR4PYDQw5c6m+zOvGRvB9G46cHh4dNFZ0pac56oFlWyqBDnazMyxWs16+3obL5/wB9KLZuOtZhIkKNxVWVODXf52KX8+GQiY590MX1LK8CWVLL/0O3xRQjBgQnTvaL58JpI3sgwMiNFhBBwOhS25dtIfPsfCb+tvoWfaqEDzWzYybVCgaVqhak8qxcU7gQv217dFaP2HABi5YaKZmyWg0su6EwBW7uijA/xs3e8AxckHXwNGmdRYoNTHphIoL/BRAMhJRsa2wXgmfTNnIikzgq3Z4QzsbCTa7eaTYgCZ342ttS+ykbvHmrSbtZZ9BV6KgbB+Zn4XU72ykbtvMtAZKP7Kw+7m8mvyWWAgMzuWU7PDmPVTme5mQPVTVuJl6eoKui6sqBf4W+dn10eQJgPouWG4gR+jLc+6s5nz3AbbJ3YxY1W8FJ1z8805D45uJu4ItHj2NVLtaXCs4s2MuwJA4Z9faG98PQUePvIAkQbGN1tz62DHbIzLcVOkBvoz77OQ2GAlmV8m6ZGBwgMOllXPZ1zm5Nn92svY5KvMge28PPaane0eCOtm4sZoUIqdTF0V2m/CmxOCfZgao9XC+DEWxo8BPF6+3G1n1jo3u5wKz7xvY06dPkMd0bWCllHW1U2sSOE4ADIp9fvjZD19omFzqcqxM8CVkJluoPMXHs4ddLPtAHzk0QLOy7FOrs1VeH+Xm6RC7eLI6GfW+jmb0P8KCQ6p8LWX9xWaaI55+fyk1ryXu+rpV7eATL7ecmFfz6sUASCRFF8vmXiJbqB1AQQcLNbSte+twjK9qmHWZSqHgbSm8muW1me5cGo4CwGHzcnGTXZm5ClUFLt4PD+cdUMurv1pkGttJ4P2Nx3GWj83OM/fd3uPk6dfqmJRS90RtRJueKxMTMnQ80SOjwO7nOz7hZ4TgeZ4SoaFjKDS7Tin8sr5Y2+tnzEhNZzlh+p/w9fIVYGPMCYNisY5qJFEImWyQBuCVGZn0R4LwwbLgJ/Pv7Sz/RKW/1ILyYDpKXZxIs5Mr5oKkYGBGdFs9Z0naq0PpUThENQLLM3oJJEAFKJw4FugdtBUfHxVDiDRs2vgt94mbg/3sLLKx9zNfuzoGHONhbQ4H0m5bgr22HihBEDPmAwDzekz1EjKVhcHPF4eXe9k5JiGwchzqIrFhQA6Rg+q/2pZos6kTs3tS4lK/cr3FVFabdnS3cSSwY0FL7neTVwvvyYpHDnl5crECy/mrBEWxmcbcZ07x7QjcKjIA9TaHxU8ULO+L6S+p63w4SobCwr9RPWwsG1qGKlWGY/DwUPP2ni1/vhEoKljFX2didEbfeSUenn9kJOzh/yAzB2DG+/DDjVvv1ZB8txoZnaTuLF3/aaPjxIHEAlnC53845tGvnDj8vFV9XLPCBamVV93OjKHRzD5y3Jeb/R4hr7Qa5JX2vifpRWkPX6ep/e6L/SFKR7WFGj9HnK8TO/WpGm1ML4HgMpf363kSE1Hn48v1rn4WAViDUy8smYDbumpA1QKTvvBqGdcqnyhf7NYoUAFkgxkt9Qcjw/nr1laX9+RXBs35Ng5XSv/gzvKGLjcQzEQ1dvCsrQWamRWE9d30fZl5fu2C2kpHt58112ndgmQ2d9AFOAsUZFSrEy+LkL7kyphU/WMv85KUgu70Jiz+RVkLqqg758r2Hj2wrhYT5mDDYGo3TtBC40/jglcZsfcLClWAuvZeOrLUIqYHj4P3PwD07VgCWA0qZTZW5lUzcsflffWOLXmeJKR39ZvEYQsD/Ne0ZrSDXnZdEJBAWJjJI58ZmP2e9qf549DmNvN85uc/AcAIy+Ot9LPAEUFVbxRDESaWPgrayNNfcCk0/pNf6QnVOedD7kapkfR0ckCSqmPBSvLWSDpiLGC26EN80CSmDGq6bfSjTMw5V4rm59ysLnQSdpcN0N6SdhP+thjA/QyD0+OqFNjvSXdQNheD3ZAvsrASBnAyvgUOyvytBv92v6WZpvjGpm0MVG8U17Br/aq7MqtomduFZHhOnzV+wRarWZaMGMwTcyeYGLtMjdHDjm4eq6LIb0kio/4OObTmp51XvykhLEs2cuUg16mPX6e57rrSUbhXydVHKqOdR6J3JtaW/NR8Oh1xOjhxFEX4550IRt1xOqh1OFHAeQ4E/87SAs60RlGMjf42KYqPLnwHM+H63BV+VFC6nFtISvJxtJSP//OKWX0dyZuwMeqL73sD659XkfGMANJeW4KS7UTnJkWzLUSQsrsTM4x8Ol4Ewn1ztOWD+1suDqSO2NMvDAvjhlnFGxmmb6dJQyqmR+7yhj1Lx8T741ichdQyt08lWPn9U4Sab+10q93OO/8wkvmRm0US+45BQUJOd7Ch0vMKHofK2aIYUVBMcaE88oTndg1wcSEJJk4M1RW+fEZdfS52sQbc2JYeOVF9ItFRrDuqSheukYmUe8n/4CPg16JAT81s/6xGB6vn2aKgZGBqFx72FDGQAPalK8yI1Kbb47X2itu+3Usp2Zb+U2STFwgYLj1OvokGXl0SgzfzIy80AXRUmpXRpM/x8rERIkwVWX7IQVvvJEV86z8vJG8s6fF8sUEEyM6Q9FJL5tO+4lLMPDolGg+bnWwBJC5YmAMXy2K4o0sI8PidUTi56zDT1i4zIisML74QzQ1lWVrBP+cbmFEvPYCz+XTMTgrnJxhoXX53XRXNOuz9HTXq2zJdfJUgUrqzWHcH3sRiXWzMLF6bmDJwD3XBXuthI5TeeXc/akPV/1/KHMyYVkZD+V7+Nqho1uigb6ROr4rdvPyKi1YJg6NbjCEiGM2Htruw4WOgVkRNUOXTq2v4tmjCnYFDHpwlCohO6yo3T+za8h4uGbZu2NRe2YtCO1IYeub57l1l5+wfmEUTQlvslXUmntCfGb34rTVZ3ZDrkkuCJe1kgoyFnmIuAJ2FmoDwR8c2XSwFC4vImAKQhs6dlTBo/eTX+hHNstMHBfJI5d61iih3YiAKQhtqOe1sey+tqNLIVwqodXrLgiCEMJEwBQEQQiSCJiCIAhBEgFTEAQhSCJgCoIgBKndA2Zyjy41y8dPnW/v7AUhpBw8XlyzXPveEEJTuwfM/j/pWrO89J1t7Z29IISUv63/oma59r0hhKZ2D5jZIwfULP9t3Q5mLNkgaprCf52Dx4uZsWQDL7+bV/Nb7XujKbLoRGu1tjxm7f5/yQF+veBd3vpgV3tnKwgha9KodFY+OrbF9TIWnafg1OX2memOlZqoZ8fDQU3y2qIOeV4tmXkrk0ald0TWghByJo1K54XZtwe17t1DxLeLW6stj1mH1DCrbdlxmDUf7WHv0TN1Or8F4YcuuUcX+v+kK9kjBzAio3XT5d63qoLVOxtMuiY0YsIgM6/eFdVm6XVowBQE4eIs3+bgzXwnB4p8KKE0cX0IkCVISdBz9xAL92e2wRcKaxEBUxAEIUjinZsgCEKQRMAUBEEIkgiYgiAIQRIBUxAEIUgiYAqCIARJBExBEIQgiYApCIIQJBEwBUEQgiQCpiAIQpBEwBQEQQiSCJiCIAhBEgFTEAQhSP8PpMdEouPdeaQAAAAASUVORK5CYII=) ## Schedule Your Order[​](#schedule-your-order "Direct link to Schedule Your Order") Choose to either schedule your order to match circuit enablement OR to match completed installation. ### Match Circuit Enablement[​](#match-circuit-enablement "Direct link to Match Circuit Enablement") To place your order on hold to match the date that your circuit is enabled, select *Circuit Delivery Date* and select a date from the calendar. This is the date when your Carrier commits to enabling the circuit. After your Carrier delivers the service, Equinix completes the installation. Enter or upload additional details and instructions that might help the Equinix technician. When all the order details are correct, click **Next**. ### Match the Completed Installation[​](#match-the-completed-installation "Direct link to Match the Completed Installation") To schedule the date for your completed installation, select a date in the calendar view. You can select from a date range suggested by Equinix. Or, you can request a different date based on your schedule and pricing needs. Select one of these calendar options: ![Installation date calendar](https://docs.equinix.com/assets/images/xc-order-calendar-a0c266b203ced246a88b18abdf398dd4.png) * Flexible (F) – Your order is completed on a date that Equinix recommends, and you receive a discount on your installation charge. * Standard (S) – Your order is completed during a typical, guaranteed installation interval. * Expedited (E) – Your order is completed more quickly. Click a date in the calendar, and choose a time from the drop-down list. Approval is required, and additional fees might apply. Click **Next**. ## Provide Contact Information[​](#provide-contact-information "Direct link to Provide Contact Information") In the *A-side Contacts List*, you are automatically assigned as the technical contact and the notification contact. To add additional contacts, complete one of these steps: * Click the Search for a contact field, begin typing a name, and select the name from the filtered drop-down list. ![Provide Contact Information page](https://docs.equinix.com/assets/images/xc-orders-diloa-a-contacts-f657f8aff6a94eb3fd6718df540bfef4.png) * Click **Add from Directory** to search the Contact Directory list. Select one or more contacts, and then click **Done**. * If the contact you want to add is not included in these lists, click **Add New Contact**. Complete the *Add an Unlisted Contact* form and click **Add**. The contacts that you add are automatically assigned as a Notification Contact to receive order updates. You can select one of them as a Technical Contact. In the Z-side Contacts List section, select *Notify Z-side contact* upon completion. Enter the contact email address. Click **Next**. ## Review and Submit Your Order[​](#review-and-submit-your-order "Direct link to Review and Submit Your Order") After you have reviewed the information for this new Cross Connects connection, you can make final changes and complete the ordering process. 1. In the Review Order form, verify that the Connection Details, Additional Details, and Contact Information sections are correct. 2. Enter additional Customer Reference information. 3. In the Terms and Conditions section, click **Review Terms and Conditions**. 4. Review the *Acceptance* section and click **Accept**. ![Terms and Conditions window](https://docs.equinix.com/assets/images/xc-orders-diloa-terms-b813ba5da3ae81c54fed7849965e2869.png) 5. Click **I Accept** and **Submit**. The *Order Submitted* confirmation window displays your order number. ![Order Submitted confirmation](https://docs.equinix.com/assets/images/xc-order-success-options-3acf4a9a4aa2711315e9ce361d7933d8.png) To find details about the status of your order, click **Track in Order History**. After your order is completed, you’ll receive a **survey email** inviting you to provide feedback on your experience. This survey allows you to comment on how the order was fulfilled and whether you were satisfied with the work performed.
