# Completing an Offline Cross Connect Order > **New Customer Portal Experience** > > Equinix is upgrading its systems and the [user experience](https://docs.equinix.com/releases/experience-updates.md) in the Customer Portal. Products and services ordered through an offline ordering process can be configured and completed in the Customer Portal. Equinix offers ordering Cross Connect through a formal quote and offline ordering process through the Equinix Sales team. Once you have received and accepted the quote, you get an order confirmation with a link to the Customer Portal where you can finish configuring your order and create your service. ## Finding the Order[​](#finding-the-order "Direct link to Finding the Order") You can access the order in one of two ways, from the email notification that your order has been created, or from your *Order History* in the Customer Portal. To access the order from the Email Notification: 1. Click the link in the email with the subject line: "Action required: Configure your Order# ``" To access the order from the Customer Portal: 1. Sign into the [Customer Portal](https://portal.equinix.com). 2. From the *Colocation Dashboard*, click on *Orders*, then *Order History*. ![Orders menu with Order History highlighted](https://docs.equinix.com/assets/images/cc-order-history-47af1c01597ea8114d34db28e46913c5.png) 3. In the *Order History* table, search for the order number. * You can also use the filters to show only Cross Connect orders. 4. Locate the order, then hover over `Action Required` until **Configure** appears, then click it. ![Orders History page with an Action Required order](https://docs.equinix.com/assets/images/cc-order-history-table-f90937c6aa8657998d449e4a45168cce.png) 5. Select the Cross Connect order that you want to configure, and click **Configure**. ![Action Required window with the Configure button](https://docs.equinix.com/assets/images/cc-select-order-0460d615631ec5140850babbc435aecb.png) ## Completing Your Order[​](#completing-your-order "Direct link to Completing Your Order") Complete your Cross Connect order using the on-line ordering flow. Configuration values derived from your quote cannot be changed. ### Standard Order[​](#standard-order "Direct link to Standard Order") The quote process does not verify whether you have a Letter of Authorization (LOA), a LOA, or an existing connection with the same customer. As a result, all three options remain available and follow the standard workflow to connect to a provider. ![Specify LOA Preference page](https://docs.equinix.com/assets/images/cc-select-LOA-bd3813198117997ee8889833f033ceb7.png) Select a provider and click **Next**. ![Order Without LOA with Connect to a provider selected](https://docs.equinix.com/assets/images/cc-provider-cb3f4a82c7e4865e061b9ee3c0a4588c.png) On the *Configure your Cross Connect* page, complete the connection details to continue. * Click the pencil icon to assign connection details such as cage, cabinet, patch panel and port information. ![Configure your Cross Connect page](https://docs.equinix.com/assets/images/cc-configure-cross-connect-164a57f0345f118e648eb5eb2a406ae2.png) * Complete asset details for the A-side and Z-side , then click **Save and Close**. * Submit separate orders for additional quantities. ![Asset Selection Details panel for the A-side](https://docs.equinix.com/assets/images/cc-asset-details-81c82dc05ed8070ef6be6829cf0e5c52.png) ### Extended Cross Connect Order[​](#extended-cross-connect-order "Direct link to Extended Cross Connect Order") Unlike the standard workflow, extended cross-connect orders follow the Building Meet-Me Room (BMMR) workflow. 1. In the *Specify LOA Preference* page, attach a Letter of Agreement, and select **Next**. ![Specify LOA Preference page](https://docs.equinix.com/assets/images/cc-specify-LOA-540c4cbfe1ebf969f4fed40d504adede.png) 2. On the *Configure your Cross Connect* page, complete the connection details to continue. * Click **Assign port information** to open *Asset Select Details* where you can assign asset details such as cabinet, patch panel, connector types, and ports. ![Configure your Cross Connect page for a Building Meet Me Room](https://docs.equinix.com/assets/images/cc-configure-cc-11ce928e4ae127513832c9e1a1aea7ea.png) ![Asset Selection Details panel for the A-side](https://docs.equinix.com/assets/images/cc-configure-asset-details-433085fa730a901994617e68d20fcaaa.png) 3. In *Schedule Your Order*, select a scheduling option, and click **Next**. 4. The *Provide Contact Information* panel displays the Ordering Contact and Technical Contact information. These contacts are derived from the quote and cannot be changed. ## Review Your Order[​](#review-your-order "Direct link to Review Your Order") 1. Review the order including *Connection Overview*, *Connection Details*, *Additional Details*, and *Contact Information*. 2. Optional: Click *Add Purchase Order Number* to associate a purchase order with the order. You can also enter a *Customer Reference ID*. 3. Click **Submit** to complete your order. After you place the order, you can track its progress in Order History.
