# Z-Side Opt-In This optional feature allows other Equinix customers to connect with your organization's cages when they place a standard cross connect order. This feature is only available to company administrators. > **Important** > > By using this feature, you acknowledge that your organization is allowing other Equinix customers to see and select your cages as their Z-side connection. You also affirm that you have the authority to make this Opt-In selection on behalf of your organization, and that Equinix is not responsible or liable for any information that becomes available to other customers by your choice to opt in. For more information, contact your Equinix Customer Success Manager (CSM). 1. Sign in to the [Customer Portal](https://portal.equinix.com/). 2. From the *Administration* menu, choose **Account & Security Management**. 3. Click **Z-Side Opt-In**. 4. Select one or more accounts. 5. Click **Submit**. The cages/suites for the chosen account(s) are now selectable as a Z-Side option when other customers place a standard Cross Connect order.
