Secure Cabinet
Equinix Secure Cabinet products support deployments ranging from single cabinet to more than 10 cabinets. Secure Cabinet offers globally available space and power tailored for regional differences.
Equinix IBX data centers enable Secure Cabinet products to connect customers to a global footprint, with presence in North America, South America, Europe, Middle East, East Asia, and Australia.
A Secure Cabinet in an IBX data center provides access to Equinix's interconnected ecosystem and to Platform Equinix. IBX data centers are designed to support, protect, and connect business-critical workloads. For a downloadable overview, see Equinix Secure Cabinets – Solution Overview.
Secure Cabinets address space, power, and interconnection requirements. Deployments can start with a single cabinet or scale to multiple cabinets for expansion, allowing control over infrastructure placement as requirements change.
Main Features​
  • Security - Locking steel cabinets located within staffed Equinix IBX facilities, supported by multiple layers of physical security.
  • Cabinet construction - Locking front and rear doors on a robust cabinet made by leading cabinet manufacturers.
  • Sizing and integrated equipment - Industry-standard cabinet sizing, interconnection-ready private single-mode fiber patch panel and equipment-mounting capabilities.
  • Power configuration - kVA-based power allocations and circuitry to support draw caps and planned utilization.
  • Redundancy and uptime - Power circuit selection and configuration based on defined criteria to support power availability and consistency.
  • Direct interconnection - Private, direct data exchange (interconnection) providing access to Platform Equinix and connected partners and providers.
  • Hardware parts - Patch panels, cables, shelves, and cabinet-based power distribution units (PDUs)
  • Cable management - Accessory parts for both vertical and horizontal cable routing that can be preinstalled by Equinix to assist with efficient intracabinet patching.
  • Optional services - Troubleshooting, remote management, 24/7 support, and equipment installation.
Secure Cabinet comparison​
Secure Cabinet ExpressSecure Cabinet
Fully featured, deployment-ready cabinet offering used for common cabinet and power configurationsConfigurable option for specialized technical requirements with flexible deployment locations
Space
Cabinet1200 mm minimum depth. Accommodates most equipment needs. Equinix-owned cabinetryConfigurable with Equinix or approved customer-provided cabinet
InstallationReady for service; built to standard specification, globally; move-in ready units availableStandard installation, built to order
Power
Contracted draw capSelectable up to pre-deployed local business maximum (5kVA or greater, depending on site)Dependent on deployed circuit configuration. Selectable up to circuit-usable kVA
Capacity approvalPre-approved up to local business maximumStandard capacity review process
Interconnection
Demarcation panelStandard single-mode fiber connectionsConfigurable: copper, fiber (single, multi-mode)
Securing infrastructure​
Each Secure Cabinet includes physical infrastructure to house equipment within an Equinix IBX data center.
  • Locking cabinet doors to restrict physical access to installed equipment.
  • Standard configurations include industry-standard internal equipment mounting, space for power distribution units and cabling, and provisioning for secure interconnection to the Equinix ecosystem.
  • Power and environmental service level agreements covering defined operating conditions.
Allocated capacity using kVA-based power​
Allocated power draw, also referred to as draw cap, is a threshold measured in kilovolt-amperes (kVA). Capacity planning aligns planned power consumption and associated cooling for each Secure Cabinet.
  • Determine your draw cap defines current and planned power requirements for the deployment, based on evaluation with an Equinix representative.
  • Know what affects draw cap identifies factors such as cabinet ratings, circuit availability, and deployment density.
  • Protect your deployment supports selecting an appropriate draw cap to reduce excessive power and cooling use in a shared environment. Using draw cap allows focus on business requirements rather than the technical details of colocated space and power.
Power design for uptime in modern deployments​
Redundant power circuits are integral to each Secure Cabinet deployment.
  • Power configuration supports circuit selection based on deployment requirements to address current and planned infrastructure needs.
  • Power circuit selection for safety and consistency keeps equipment safe and running smoothly. Selection is based on equipment power requirements, cabinet draw cap, and cabinet ratings.
Direct interconnection access to partners and services​
Each Secure Cabinet is provisioned for private interconnections to partners and providers within the Equinix ecosystem.
  • Private network demarcation point provides a single‑mode fiber patch panel integrated with each cabinet, supporting physical separation from other tenants and control over provisioned connections.
  • Direct access to customers and interconnection services enables interconnection with other customers through Equinix Cross Connects, Equinix Fabric, Equinix Connect, and Equinix Internet Exchange, provisioned directly through the integrated demarcation point.
Additional Secure Cabinet offerings​
All cabinet locations are engineered with direct access to the data distribution system for quick deployable interconnections.
Equinix performs all installations of cabinets and power circuits.
