# Ordering Secure Cabinet Express The Equinix Customer Portal enables online ordering of Secure Cabinet Express, along with additional products and services like Smart Hands, Cross Connect, and Fabric. Existing deployments can be amended by ordering additional power, circuits, and cabinets. The application supports direct end-customer and reseller purchases. For general information about reseller capabilities, see [Resellers and Reseller Administrators](https://docs.equinix.com/iam/roles-permissions/admin-resellers.md). ## Prerequisites[​](#prerequisites "Direct link to Prerequisites") Before you can submit a colocation order online, you need: * A billing account registered for the country where you want to order colocation assets or add-ons. * An Equinix Customer Portal account with the `Colocation Ordering` permission. To view your current permissions or request more permissions, see [Permissions](https://docs.equinix.com/iam/roles-permissions/ecp-customer-permissions-request.md). ## Placing an Order[​](#placing-an-order "Direct link to Placing an Order") 1. Log in to the [Customer Portal](https://portal.equinix.com/). 2. From the *Orders and Tickets* menu, select **Order a Secure Cabinet**. > **Tip** > > If you start an order but do not finish it, you can save a draft when you exit the screen. When you return later to the ordering screen, you can choose to continue the unfinished draft or start a new order. (If you start a new order, the unfinished order is deleted.) ## Project Type and Billing[​](#project-type-and-billing "Direct link to Project Type and Billing") Select the project type for this order: * Reseller Project – Order Secure Cabinet Express for an end-customer project. * Own Purchase – Order Secure Cabinet Express for your own deployment. - If you are purchasing as a Reseller for your end-customer, select *Reseller Project*. ![Select Project Type page with Reseller Project selected](https://docs.equinix.com/assets/images/select-reseller-project-9a3a2890143a353f6308780bc15352e0.png) 1. Click *Select End Customer*. 2. Choose a customer from the list or enter it manually to add a new customer name. Click **Select**. ![Select End Customer window](https://docs.equinix.com/assets/images/select-end-customer-58a8e10b701342b516c862798daec15e.png) 3. Click *Select Billing Account*. 4. Choose a billing account and click **Select**. ![Select Billing Account window](https://docs.equinix.com/assets/images/select-reseller-billing-acct-114fe389803e1f55f7a16ae1900f1a5e.png) 5. Click **Next**. - If you are purchasing for your own use, select *Own Purchase*. ![Select Project Type page with Own Purchase selected](https://docs.equinix.com/assets/images/select-own-purchase-82fe29d1f9d7176635d49c491b005d4e.png) Select a billing account and click **Next**. > **Note** > > The billing account's country determines the locations where you can order cabinets. ## Selecting a Location[​](#selecting-a-location "Direct link to Selecting a Location") The *Location* screen shows a list of data centers that offer Secure Cab Express. The list only includes data centers associated with the selected billing account. ![Select Location page listing data centers](https://docs.equinix.com/assets/images/select-ibx-location-list-70cce850f414dd60f20add93e6811d83.png) * The Min/Max kVA column shows the minimum and maximum power draw caps available (per cabinet). * The *Availability* column shows whether Secure Cabinet Express (SCE) is currently available at the IBX data center: * High: 30 or more available * Medium: 10 to 29 available * Low: 1 to 9 available * The *Billing Account Assets* column shows whether you already have Secure Cabinet Express deployed at the IBX. * The *Monthly Recurring Charges per kVA* column shows the pricing for space and power. - To see the connections available for an IBX, click **Check IBX Connections**, then select an IBX from the A-side IBX or Z-side IBX list. ![IBX Connection Check panel](https://docs.equinix.com/assets/images/colo-scede-check-ibx-connections-7837f3c5204c5267d3a141efb1d0704b.png) - Or to see more details about the location, click **i** to the right of the IBX. ![Location list with the information icon highlighted](https://docs.equinix.com/assets/images/colo-scede-ibx-information-e2ceb092a63c63e65e51781b44cf99c6.png) ![IBX Data Center Details panel](https://docs.equinix.com/assets/images/colo-scede-ibx-information-panel-6045a50fb3703beea85a14d13d429267.png) Choose an IBX that has availability, then click **Next**. ## Configuring Your Cabinet[​](#configuring-your-cabinet "Direct link to Configuring Your Cabinet") On the *Configure Cabinet(s)* screen, add cabinets and adjust their configuration. > **Tip** > > The maximum number of spaces available in a single cage at this IBX is listed. This is the maximum number of new cabinets you can add to this order. (Additional spaces may be available in other cages. To deploy cabinets in two separate cages, you must create two separate orders.) > > Example: Suppose you want to deploy 4 Secure Cabinets, and suppose the IBX has 4 spaces available, but the Maximum number of Cabinets in Cage is currently 3. This means three of the available spaces are in a single cage (cage A), and the last available space is in another cage (cage B). Create an order for three cabinets in cage A, and create another order for one cabinet in cage B. 1. Select the cabinet dimensions, and click **+ Add Cabinet**. ![Configure Cabinet(s) page with cabinet dimensions](https://docs.equinix.com/assets/images/select-cabinet-dimensions-6ed8805e0ecea960617ac0261398c813.png) 2. On the *Add Cabinet Details* panel, select your configuration options: * Circuit configuration – Choose from one single phase circuit, two single phase circuits, or one three-phase circuit (each with redundant pair configuration). * PDU – If you want to use your own PDUs instead of the recommended Equinix standard PDUs, deselect this option. Then after you submit your SCE order, [submit a Smart Hands order](https://docs.equinix.com/smart-hands/ordering/sh-how-to-order.md) to have your own PDUs installed in the cabinet. * Equinix Fabric Port – (under *Additional Elements*) If Equinix Fabric is available at the IBX, and if you have network port permissions, you can select this option. Equinix Fabric allows the creation of on-demand virtual connections to any customer or cloud service provider located in any IBX data center. 3. Click **Save**. 4. (*Optional*) To add another cabinet to your order, click **+ Add Cabinet**. Select the configuration options and click **Save**. 5. Under *Draw Cap*, select the desired amount of kVA. > **Important** > > This is the aggregate power draw cap for your entire order (not per cabinet). 6. Under *Term Length*, select the contract term, from 24 months to 60 months. * Your term length selection does not affect the pricing of the current order. * The prices quoted in your order are guaranteed for the length of the contract term. 7. Click **Next**. 8. Under *Recommended Additional Services*, enable or disable the options. ![Recommended Additional Services page](https://docs.equinix.com/assets/images/colo-scede-additional-services-6705847bf0aff89f74c1c40739246bd4.png) * For the Cross Connect package, you can select up to 20 single mode fiber (SMF) cross connects. * If Smart Hands is available at the IBX, and if you have the necessary permissions, you can select a Smart Hands Support Plan with up to 1000 support hours. To see where Smart Hands is available, refer to [IBX List/Smart Hands Availability](https://docs.equinix.com/smart-hands/sh-services.md). For plan details, see [Smart Hands Support Plans](https://docs.equinix.com/smart-hands/support-plans/support-plan-packages.md). 9. Click **Next**. ## Review Cabinet Location[​](#review-cabinet-location "Direct link to Review Cabinet Location") Under *Review Cabinet Location*, select a cabinet space within the IBX. ![Review Cabinet Location map](https://docs.equinix.com/assets/images/colo-scede-cab-location-6cc3399eee7b688697b85d493710c39e.png) > **Note** > > If your order contains multiple cabinets, they must all be deployed in the same cage. If you want to deploy cabinets in two separate cages, you must create two separate orders. 1. Select a cage from the list to see a diagram of the cabinets in that cage: * The default location selected for your new cabinet is shown in blue. * Other available cabinets are shown in white. * Cabinets that already belong to the selected billing account are shown in orange. * Unavailable cabinets are shown in gray. > **Tip** > > To move around in the diagram, click and drag it with your mouse. To zoom in or out, use your mouse wheel or click the +/- buttons. 2. Click an available cabinet (in white), or accept the default selection (in blue). 3. If your order contains another new cabinet, click the cabinet number under Product, then select an available cabinet in the cage. Repeat for all new cabinets in the order. 4. Click **Next**. > **Note** > > If a colocation space visualization diagram isn't available for the IBX, choose a cage/cabinet from the drop-down lists. ## Contact Information[​](#contact-information "Direct link to Contact Information") Under *Contact Information*, specify at least one Notification Contact, and optionally, a Technical Contact: | Contact Types | Description | | ---------------------------- | ------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------ | | Technical Contact (optional) | For troubleshooting or clarification of the order. Technical contacts do not receive booking or completion notifications. Only one person can be selected as a Technical Contact. The Technical Contact and the Notification Contact can be the same person. | | Notification Contact | Contact(s) who will receive email notices about the status and pricing of the order. | 1. If you want to add another contact person to the order, click **Add from the Contacts Directory**. Select their name or use the search box, then click **Next**. (For Technical Contacts only) If the person is not listed in the directory, click **Add Unlisted Technical Contact**. Enter their contact info and click **Done**. An unlisted contact cannot be selected as the Notification Contact. 2. For each person, verify the contact information, and adjust the phone call availability and contact type settings. 3. If the selected billing account requires a purchase order, click **+ Add Purchase Order Number**. Select a purchase order to associate with your order, then click **Next**. 4. Enter *Customer Reference* information. This field provides a place to enter your internal reference information, such as P.O. numbers, ticket numbers, or descriptive text. This information can be searched for on the *Orders and Tickets History* screen, and will also appear on any related invoices. ## Review Terms and Conditions[​](#review-terms-and-conditions "Direct link to Review Terms and Conditions") 1. Click *Order Terms and Conditions* to review the contract terms. * If the order should be signed, select *eSignature* or *Wet Signature* and then click **Select Signature Option**. Specify the person in your organization who is authorized to approve the order, then click **Save**. The specified approver will receive a signature request via email. The order will not be processed until it is approved. * If the account does not require a signature, select *Click to accept* and then click **I Accept**. ## Review Order and Submit[​](#review-order-and-submit "Direct link to Review Order and Submit") 1. Click **Review Order** and check all the information carefully. ![Review Order page](https://docs.equinix.com/assets/images/colo-scede-order-details-1d75a0c1737c5080c319984432581256.png) > **Info** > > Click *Contractual Terms* to review the price increase terms that may apply after your contract expires. 2. Click **Submit Order**. ## Monitoring Your Order[​](#monitoring-your-order "Direct link to Monitoring Your Order") After you submit your order, you can monitor the status in the [Customer Portal](https://portal.equinix.com/). For details, see [Orders and Tickets History](https://docs.equinix.com/colocation/managing-orders/orders-tickets-history.md). ![Order activity timeline with Pending Approval status](https://docs.equinix.com/assets/images/colo-scede-order-status-7c6a4665652620aa9fadd98448fe3f8f.png) > **Note** > > It might take a few minutes for new orders to appear on the History screen. ## FAQs[​](#faqs "Direct link to FAQs") Frequently asked questions about ordering Secure Cabinet Express in the Customer Portal. ### Why can't I find my billing account?[​](#why-cant-i-find-my-billing-account "Direct link to Why can't I find my billing account?") * Has your company created a billing account? Before you can place an order for Secure Cabinet Express, your organization needs to register an account to be used for billing purposes. To register a billing account, contact your Equinix Sales Representative or contact [Equinix Customer Support](https://www.equinix.com/contact-us/customer-support). * Is your existing billing account enabled for your own purchase? Some billing accounts can only be used for end-customer projects, not for your own purchase purposes. To create an account for direct-purchase projects, contact your Equinix Sales Representative or contact [Equinix Customer Support](https://www.equinix.com/contact-us/customer-support). ### Why is my billing account grayed-out?[​](#why-is-my-billing-account-grayed-out "Direct link to Why is my billing account grayed-out?") The account is not currently eligible for orders, either because it doesn't have an active Master Country Agreement (MCA)/General Terms and Conditions (GTC), or doesn't have a valid billing address. Contact your Equinix Sales Representative or contact [Equinix Customer Support](https://www.equinix.com/contact-us/customer-support). ### Why can't I order a Secure Cabinet Express for a different country?[​](#why-cant-i-order-a-secure-cabinet-express-for-a-different-country "Direct link to Why can't I order a Secure Cabinet Express for a different country?") To order cabinets for a specific country, you need to have a billing account registered for that country. ### Is a purchase order (PO) required?[​](#is-a-purchase-order-po-required "Direct link to Is a purchase order (PO) required?") It depends on the billing account you selected for the order. Some billing accounts are configured to require purchase orders. For other accounts, a PO is optional. If the billing account requires a purchase order, you will not be able to submit the order until you select a valid PO. ### What's included in the non-recurring charges?[​](#whats-included-in-the-non-recurring-charges "Direct link to What's included in the non-recurring charges?") Non-recurring charges (NRC) include: * Cabinet installation fee * Circuit installation fee x2 ### What are my order acceptance options?[​](#what-are-my-order-acceptance-options "Direct link to What are my order acceptance options?") It depends on the billing account you selected for the order. Some billing accounts are configured to require a digital signature by an authorized person. If a signature is required, a signature request will be emailed to you (or to another person you designate during the order process). The order will be on hold until we receive the signature. ### Can I order Equinix Fabric with Secure Cabinet Express?[​](#can-iorder-equinix-fabric-with-secure-cabinet-express "Direct link to Can I order Equinix Fabric with Secure Cabinet Express?") Yes. If Equinix Fabric is available at your selected IBX and if your account has Network Port ordering permission, you can include Fabric in your SCE order. ### Can I use Smart Hands for my cabinet?[​](#can-i-use-smart-hands-for-my-cabinet "Direct link to Can I use Smart Hands for my cabinet?") Smart Hands services are available in most (but not all) IBX locations. For a list, see [Smart Hands Availability](https://docs.equinix.com/smart-hands/sh-services.md). To use Smart Hands, your account must have Smart Hands ordering permissions. To check your current permissions, go to your user profile in the Customer Portal. To learn how to request additional permissions, see [Permissions](https://docs.equinix.com/iam/roles-permissions/ecp-customer-permissions-request.md). ### Why can't I add a Smart Hands Support Plan to my order?[​](#why-cant-i-add-a-smart-hands-support-plan-to-my-order "Direct link to Why can't I add a Smart Hands Support Plan to my order?") * You might not have permissions To add a support plan to your order, you need specific portal permissions. For details, see [Smart Hands Support Plans](https://docs.equinix.com/smart-hands/support-plans/support-plan-packages.md). To check your current permissions, go to your user profile in the Customer Portal. To learn how to request additional permissions, see [Permissions](https://docs.equinix.com/iam/roles-permissions/ecp-customer-permissions-request.md). * Smart Hands might not be available at the selected IBX Smart Hands services are available in most (but not all) IBX locations. For a list, see [Smart Hands Availability](https://docs.equinix.com/smart-hands/sh-services.md).
