View Your Accessories Permissions
To see your current permissions in the Customer Portal:
Click your user name and select User Settings:
Click the Permissions tab.
Verify that the Ordering tile says
Permissions Granted. -
Click the Ordering tile.
The Accessories column shows your permissions for each IBX data center.
If you don't have the permissions you need, contact your company's portal administrator, or refer to Permissions
